Results 1 to 10 of 107
Thread: Engine Oil: what's best?
    KWAWD's Avatar
    May 2012
    I've been using Nulon 10W-40 full synthetic in the 380 6G75 motor and found it to be long lasting. Thats subjective and based on the colour of it, but it always looks clean on the dipstick and when drained it still looks serviceable, not black as hell.
    My view these days is that the premium brand full synthetics are the best choice and you just need to pick one or two that you like. I tend to go with 10W-40 grade in the 380 motor.
    I frequently, at least every 6 months or 7000 k's whichever comes first, replace the engine oil myself using a siphon. Thats frequent I know, but thats what I want. I cant do a drain from the sump at my apartment building because theres no working space around the car and I wouldnt trust all the transients walking around to keep clear of the car or the jack while I'm under there. I've found the siphon method is quick, takes about 20 mins and gets nearly 4.5 litres or more out which must be most of it, so its pretty easy to do.
    This means the filter gets replaced every other service by my mechanic, about every 12 months say.
    Well this past week I had some service items done by the mechanic including getting the filter replaced and the oil drained. He insists on using his own oil because its all setup in drums in his workshop with hoses and easier for him, which is fine because I just siphon it out afterwards and put my own preferred oil in so that I'm happy.
    He used Magnatec "Pro" this time. I dk what that is but assume its the budget mineral variiety. What is up with this oil? I must have driven it no more than about 50km's before draining it out and it was black! I mean really dark. It looked reasonable on the dipstick, a little dark, but once out in a container you could see its pretty much black.
    Theres a few possibilities;
    1. Maybe its dark to begin with?
    Anyone know?
    2. Maybe its darkening on first use by design?
    Something in the oil goes dark once heated up?
    3. Maybe its got a lot of cleansing agents in it and its doing more cleaning than other oils?
    But I cant believe the motor is that dirty! And surely too much cleaning agents cant be good either!
    I mean, it was no more than about 50k's. Its a mystery to me. I'm just not expecting it to be that dark after one trip!
    If anyone has experience with this oil let me know.
    Put the Nulon in and drove it until it warmed up, a few k's, came back and drained a little out and it looks like new, as you'd expect.
    Feb 2011
    A 4th possibility is that your mechanic accidentally put in used oil.
    If you are saying the oil he put in was darker after 50km than the Nulon after 7000km, that seems to be the most likely explanation.
    One oil shouldn't clean out the engine so much better than another.
    KWAWD's Avatar
    May 2012
    Quote Originally Posted by Shepherd View Post
    No way I believe that happened.
    Maybe I should try and describe it better:
    On the dipstick it looks dark, like dark honey, but not jet black like old oil does.
    In the drainage container it all looks very black, you couldn’t shine a light through it for instance.
    The Nulon, OTOH, looks a light golden colour and translucent.
    Maybe some cheaper oils are just dark from new.
    Feb 2011
    I found the Safety Data Sheet for Magnatec Professional A5 5W-30. It describes the colour as "dark brown", so it seems that it is unusually dark.
    KWAWD's Avatar
    May 2012
    Thank you Shepherd! That must explain it. Stuff is ugly thats for sure.
    Personally, I would be very surprised if any oil manufacturer/retailer attempted to market any engine oil that could be described either visually or in words as being "dark brown".
    Checking both of the data sheets in this link( both in page 5 of 9 of the respective documents under "Appearance" - "Colour" ):
    https://msdspds.castrol.com/msdspds/...edmb=No&cols=0
    A5 https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/E197FFA34267F52F802583930057F6EF/$File/11445843.pdf
    C3 https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/49468C44EC50286B8025828F0052B4FE/$File/11350908.pdf
    only referred to "brown".....not "dark brown".
    @Shepherd, you were possibly looking at a different data sheet to the ones I found for this type of oil?
    The reason that I would be very surprised is that most customers of mine(or of other salesmen) seeking to purchase a used car, would at some point check the appearance of the engine oil via the dipstick.....unless the used car industry has undergone very significant changes since I retired a number of years ago.
    Many would not pass a comment about oil that appeared transparent or generally of a lighter shade of brown.
    To them, it was how they perceive that it should be.
    If it was dark, they are generally quick to remark that "this oil is old"..... "the car needs servicing"....."didn't you just say that the car has been recently serviced in your workshop?" or similar comments.
    (often, this is a bargaining tactic used to attempt to force the price down aka "objections")
    If I told them that "yes, this car has been workshop serviced, but the oil they use is "dark brown", my credibility would instantly disappear.....leading to much reduced chance of a sale.
    No.
    An oil manufacturer or retailer would be asking for customer backlash by attempting to convince customers, either home mechanics or workshops, that a dark coloured oil straight out of the container was the "norm".
    P.S. I looked at 3 different sources for reviews of this product, totaling some 20 reviews, and not one made mention that the oil appeared "dark".
    If it were indeed so, I would have expected at least one reviewer to pass a comment about it's appearance.
    P.P.S. Another data sheet:
    https://cdn.opieoils.co.uk/msds/cast...nalA55w-30.pdf
    provides the description of appearance as "Amber"....."Light".
    See section 9.1 on page 6 of 10
    9.1 Information on basic physical and chemical properties
    Appearance
    Physical state Liquid
    Colour Amber. [Light]
    That is how I would perceive any passenger car petrol engine oil fresh out of the container to be.
    As stated above, I would be very surprised if it were otherwise.
    Feb 2011
    The Safety Data Sheet I found was for Magnatec Professional supplied by BP Singapore (which would be what we get) whereas the SDS showing the colour as light amber is for oil supplied by Castrol UK - so there could be a difference in colour (though I agree that dark brown would be an odd choice). The other 2 SDSs are for Magnatec Stop-Start.
    I should add that the SDS for the Singapore oil is dated November 2010, so it might not be current. Also I don't know if its the correct grade.
There are currently 2 users browsing this thread. (0 members and 2 guests)
